XCO bike- converting 100 mm travel to 120
gadi-perl
Hi guys
I currently have a 2017 Silverback Sesta Pro. Its fairly new and im enjoying it but have been toying the with idea that i would like more travel in front..( i demo-ed a big suspension, big tire e-bike, must say it was so much fun)
After that weekend of riding, i realised the xco vibe is cool but trail is better.
The suspension guys say its possible to insert a spacer or something and created extra travel. One of my good friends in the industry recommends doing it, but others do not. they feel it
it changes the feel of the bike, the bike might climb harder , raises up the BB, and changes the nippiness on the singletrack. The fork is a rock shox sid..
Any thoughts on this would be appreciated. - Im not the most technically minded bike-wise so be gentle on the terminology :)
Thank you
its a rock shox sid. new fork i think . 2016 model
Then you simply replace the current air shaft with a 120mm version. Just ensure that you buy the correct one.
Take your bike to Stoke Suspension - they'll sort you out.
If it is the 2016 then it's just a matter of swapping a spring out. Not the cheapest exercise, but might be worth the spend.
I did this to my Scalpel , as we don't get the SE in SA...
Was 100/100
Now 120/ 115...
Yes BB is a wee bit higher, but you can ride a bit softer....
And yes, trail riding is 300% better...
There's no replacement for displacement....
Im sure the guys at STOKES are the right guys to chat to
Im getting many opinions.. guess im asking too many people haha
One metaphor is " you wouldnt put 4 x 4 tires on a Porsche" etc..
ie dont mess with the geometry and the flow of the bike.
Wouldnt the front tire want to lift up climbing steep hills?
ba humbug .... go and fit the longer travel fork already ... it is not like you are drastically altering the geo with the 20mm increase in travel.
Is the frame still under warranty, if so, check with Silverback first if they will allow you to fit a longer travel fork.
Hey G-P, pull into Stoke and let's have chat. Lots of options to get XC bikes more trail orientated. Also, as Droo mentioned, air spring is also a good option.
Also have a look on Pinkbike for the "Down Country Bike" article. Makes for an interesting read of an avenue that the industry is looking at...
 I got this done recently, it cost about R1200 for the spring (a Rockshox Reba in my case), and I think a bit extra for the fork service from Trailwolf Cycles in Pretoria.
and? how does the bike feel? pros and cons?
what was it?
