Juicy 3 brake lever a bit stuck
Piernas Flacas
  On 9/7/2018 at 12:09 PM, Wannabe said:
 Away with you, satan..... :whistling:  :ph34r:
I had Avid Ultimates and Juicy 7 on bikes.......gave up and replaced them with XT.
My son had Juicy 3 on his bike.....gave up and replaced them with SLX.
Always squealing but you get used to it.
Always getting stuck.
Always needing bleeding.
Mmmm, I have Elixers, Juicy's, X0's and Guides. Have not used the Juicy's for a while (sparing them for a commuter build), so I might have gotten things mixed up somehow.
APOLOGIES!!!
APOLOGIES!!!
You have far much patience but the Guides are nice brakes.
Gummi, I sorted the squeeling out by going the Quaxar pad and rotor route, and by taking time to do the installation / setup meticulously.  Only time they squeel for a very short period, is normally the first time I brake when going through water.
My X0 brakeset has been in constant use for the last three years, no servicing done (needed) except for pads. The rear brake has started loosing some feel / bite lately, and upon inspection once I took them off, the one cylinder was a bit sticky. Cleaned it up, new pads, and it is good to go again. That is after quite a bit of mud riding.
I have a friend on Xt's, and we know when he is approaching from behind, because of his squeeling brakes. So it is not just a Sram / Avid thing. It is how you set up your brakes, and bed your new pads in. Do it correctly, and you have no problems.
Unscrew the compression fitting and see if you can push fluid from the caliper through the hose. If not, the compression nut is corroded and pinching the hose. Replace it, the hose barb and the olive, bleed again and you're done.
If the fluid flows easily from the end of the hose, it's an issue with the lever.and you'll need a rebuild kit.
  On 9/7/2018 at 11:42 AM, Wannabe said:
Mmm, No. It is also slipped in from the top, as per attached pic.
http://oi54.tinypic.com/11ui0k3.jpg
Huh? You can see that the pads are fitted from the bottom, where the rotor goes in. And... where's the nasty clip that keeps them in place at the top? It's missing in your photo. That's why you don't struggle to seat the pads :mellow:
  On 9/7/2018 at 1:00 PM, Piernas Flacas said:
LOL... I've considered doing that. Fit SLX on my bike and transplant my Deore's to my girlfriend's bike and toss the Avids.
If you want to donate them......
:blush:
  On 9/7/2018 at 11:40 AM, Alouette3 said:
Might be a bit much fluid in the system. Sometimes the lever procedure you described can end up doing that if you give to much pressure in the syringe.
Try open the bleed screw in the lever and then push pads apart slightly. Just do so carefully so as not to let air into the system. Should help you problem.
(Avid haters go find another thread, the OP just wants help, he didn't ask about Shimano)
Initially I thought that was the problem, but is not. It's really the lever spring action more likely being hampered by the lever piston that doesn't move freely. I really made sure the bleed blocks where in place to prevent overfilling. But thanks for the suggestion.
Look on SRAM's web site under "old" maintenance manuals. They show the whole assembly, as well as part numbers.
https://www.sram.com/service/avid/68
Will try that! Thanks.
