2018 Norco Fluid 3 - chain dropping
JCC75
Howzit Hubbers,
Are there any other Norco, (Fluid 3, 29er, 1x 10) owners out there that are experincing the constant chain dropping? Bought it  August 2018.
The chain drops whether the clutch is on or not, and alwasys when not under load. it happens even on my indoor trainer??
are your using a NW chainring?
correct chain length?
thinking out loud but it may be "kick-back" from your freewheel engaging/not engaging correctly causing a drop in tension on the chain
Are you using the correct chain ring in the front? Narrow-wide? If it's just a normal chain ring then it will carry on doing so.
If you're using a narrow-wide chain ring then the chain can be too long.
These are the most obvious reasons but if it's not one of the above then one will have to start looking at other possibilities
  • 2 months later...
