Garmin Edge 520 map
Jaquesdp
It can definitely give a full map of the area while riding.
The standard Garmin maps loaded aren't great, but there are many free 3rd party maps which can be loaded to give better detail.
The only issue with the 520 pertaining maps, is the limited storage space (it doesn't have a SD card slot like the 820 etc.), so you can only have a limited number of maps on at anyone time. I normally just download the map of the area I'm travelling to in advance and then off I go.
cool thanks , think i should read some manual to see what it capability is before going out on Edge 1030
Hi Jaquesdp
The New Garmin Edge 520 Plus comes with Topo Active Africa Mapping preloaded. The other options you have are the Edge 820 and Edge 1030 which also come preloaded with mapping.
We have all the options available on our website.
- Edge 520 Plus - https://www.easybike.co.za/garmin-edge-520-plus.html
- Edge 520 Plus Bundle - https://www.easybike.co.za/garmin-edge-520-plus-performance-bundle-topoactive-africa.html
- Edge 820 Bundle - https://www.easybike.co.za/garmin-edge-820-topo-africa-performance-bundle.html
- Edge 1030 Bundle - https://www.easybike.co.za/garmin-edge-1030-bundle-topoactive-africa.html
Specials are until the end of February 2019 or while stocks last....
Regards
EasyBike
Im looking for a GPS that can give me a constant full map while riding.. Can the Edge520 do this or only if you load the selected route ?
If it is a map you are after then get a GPS, dont get a cycling computer.
The etrex 30x series has fully fledged map capabilities and you can load tracks4africa on it (T4A is well known in the 4x4 community and motorbike cirlces) and basically has every single little road, path, track ridden, walked or cycled by a human.
The etrex 30x also lets you add HR and I think cadence. The screen is great and easy to see directions.
BUT, being a GPS it does mapping first, exercise stuff second. And it runs on penlights, 22 hrs per set of 2.
If you want power and HR and laps and avg this and avg that and all the cycling related stuff, then a cycling computer is perfect. But remember at heart it is a cycling computer first and a GPS second.
Sort out which you want and go with that.
cool thanks everyone..
I already have the Edge 520 but want maps to be showed like my Car Gps  :wacko:
Try the link I sent above - I had it on a microSD in my 800's and 810's. Haven't actually bothered with the 820 yet.
Sounds like you want your bread buttered on both sides  :whistling: .  I have the 820.  But I wanted a cycling computer with GPS mapping functionality.  I only use the mapping when I am trying out new roads and need to orientate myself in a new area.  Other than that i do not used the mapping so often.  I normally preload new routes as well.  If I want a big GPS like in a car my bike will look like a stole a tray from the roadhouse.
I followed the instructions in the video below for my Edge 520 and was able to download maps to it. The space on the device is quite limited.
Thank you
Like your car GPS, you mean a view from an angle that you follow an arrow? Or you mean the view from the top and you follow the arrow ?
An etrex30x is your answer.
Speak to the guys at EasyGis who also run buycycle (I think). Best service and advice in town.
https://www.easygis.co.za/
