Need to replace my Forerunner 920XT - ideas ?
New Landy new life
Hi All
Was looking at a few options in the Garmin range for Triathlon.
Was looking at the Garmin fenix 5 that retails at R6,999 with a wrist based HRM
The Fore-runner seems more triathlon specific and there are 2 options:
1.  Normal with only writs based HRM for R 7,289
2.  Tri bundle with Chest HRM for swimming and the standard Chest HRM/run sensor  for R 9,789
Anyone have any other suggestions or makes they have used for Triathlon ?
My choise would be the 935. Its exactly the same as the Fenix5, but with a plastic housing (obviously).
I would go for the Tri bundle. The wrist unit won’t work great with swimming, and is not as accurate as a strap in general.
I would go for the Forerunner 935. The tri bundle is not so important. Normal heart rate monitor will do, unless you are really a data freak and need to know your heart rate after your swim.
Edit: As mentioned, the wrist based heart rate is a hit and miss. Not reliable at all
Hi All
Another 925? I got mine for less than R1,500 through Garmin when replacing my 910. Not sure what those others offer that a 925 doesn't
935 , for sure , as said same brain just in a lighter body and this makes it a very much more easy/user friendly unit on the wrist , i changed from a 920 to a 935 about a year back and its a power unit .
good luck
