Sidmouth Posted May 19, 2019 Share Hi Guys Need Some Help, im on a PYGA, but need to replace the front fork, Might as well get a boost fork now, I have two wheelsets a Hope pro 4 and Stand 3.30, Im just going to convert the front, do you know if the front hub just converts with one spacer which moves the rotor towards the caliper or does it come with rotor spacers, and do you know who sells theses conversion kits Link to comment Share on other sites More sharing options...
BaGearA Posted May 19, 2019 Share It comes with A dive side spacer so the rotor stays in place but the wheel has to be redished Link to comment Share on other sites More sharing options...
BaGearA Posted May 19, 2019 Share For pro4 don't know about the Stan's Link to comment Share on other sites More sharing options...
RiverInTheRoad Posted May 19, 2019 Share Evobikes has the Wolftooth kits. Its just a spacer. Works very well. Wheel needs a re-dish after. Link to comment Share on other sites More sharing options...
Meezo Posted May 19, 2019 Share Cycling stuff do a cheaper version, doesn't need redishing however you have be a little more careful every time the wheel is removed. Hope you get adaptors DTSwiss check getstokeddistribution Link to comment Share on other sites More sharing options...
Captain Fastbastard Mayhem Posted May 19, 2019 Share Yes you get kits. The majority are just 2 pieces of 15mm id tubing and a 5mm spacer for the disc. No redish needed cos the wheel still stays centred due to the 2 spacers I got a spacer kit from trail tech that replaced my hope end caps, with a 5mm spacer for the disc. Really neat. Also no redish needed. Cost me ZAR600 or so. I prefer the kits that don't require a re-dish, esp for the front. I've seen them for as cheap as 200, but then that is literally just what's described above. Link to comment Share on other sites More sharing options...
Sidmouth Posted May 20, 2019 Share Cycling stuff do a cheaper version, doesn't need redishing however you have be a little more careful every time the wheel is removed. Hope you get adaptors DTSwiss check getstokeddistributionThanks Mate, great lead, that will work https://www.cyclingstuff.co.za/product-category/bike-parts/disc-rotor-adaptors/ Link to comment Share on other sites More sharing options...
Dirt Tracker Posted May 20, 2019 Share Hi Guys Need Some Help, im on a PYGA, but need to replace the front fork, Might as well get a boost fork now, I have two wheelsets a Hope pro 4 and Stand 3.30, Im just going to convert the front, do you know if the front hub just converts with one spacer which moves the rotor towards the caliper or does it come with rotor spacers, and do you know who sells theses conversion kits Not sure about the Stans (I know MRP do a conversion kit specifically for them) but the Hopes are super simple. I've used them for a front and a back on different bikes and they have been faultless. No redishing front (or back) if you use the Hope convertor kits. They are also quite cheap compared to others. Hope: https://www.chainreactioncycles.com/za/en/hope-pro-4-110mm-boost-conversion-spacer/rp-prod180339 or https://www.rushcycles.co.uk/m50b0s472p5902/HOPE-Pro-4-Pro-2-Evo-Front-Hub-Boost-Conversion-Adapter MRP (available at Trail Tech): https://mrpbike.com/products/better-boost-hub-conversion-kits Link to comment Share on other sites More sharing options...
Yo-Yo Posted May 20, 2019 Share It comes with A dive side spacer so the rotor stays in place but the wheel has to be redished Pretty sure if you use the Hope manufactured ones then no dishing is needed on front or back. If you get one of the many kits off Ebay then you do need to re-dish. Link to comment Share on other sites More sharing options...
Captain Fastbastard Mayhem Posted May 20, 2019 Share Thanks Mate, great lead, that will work https://www.cyclingstuff.co.za/product-category/bike-parts/disc-rotor-adaptors/This is hte one that Thermophage is using, without any issues. Link to comment Share on other sites More sharing options...
Sidmouth Posted May 20, 2019 Share thanks for the advice Captain, here is the adapters from Trail Tech, saves you from having to keep track of a few spacers https://mrpbike.com/products/better-boost-hub-conversion-kits?variant=12922509525034 Link to comment Share on other sites More sharing options...
