Avid / SRAM Brake Caliper Bolt Set (rear)
MrJacques
I managed to lose the bolts of my old Juicy rear caliper :( Does anyone know where I can find a set like this locally? The bolts are easy enough to find, but I'm not sure where to get the concave / convex bits. If I can't find them can I just use other washers / spacers?
Avid-Standard-17-29-mm-Bolt-Set-for-Brak
Do you have a BoltFast in PE?
They may have.
Known as cup and cone washers.
Alibaba has too but you won't be riding for a while then.
Assuming your rear is still the IS mount with a POST mount adapter fitted you will need CPS washers underneath and on top of the mounting tabs of the caliper, assuming the caliper is "CPS Mount"
If the caliper is "Standard Mount" then you don't need CPS washers - only flat washer under the bolt head
CPS Mount caliper = ctr of bleed bolt is lined up with the ctr of the mounting tabs.
Standard Mount Caliper = ctr of bleed bolt is lined up with top surface of the mount tabs
