I need 6803 - C3 bearings to rebuild an American Classic rear hub. The supplier says he can get 6803 bearings, but not the C3.
The 6803 bearing size is standard 17 x 26 x 5 mm.
Does the C3 play a role and if so what?
Thank you.
Technical details (C3)     C3=Internal Clearance Larger Than Normal.
Bore                                C - Cylindrical Bore
Radial Internal Play     C3 Internal Play (Higher than Cn)
Edited by TNT1
Thank you, I found this that explains the Internal Clearing. https://blog.slsbearings.com.sg/why-is-normal-clearance-no-longer-the-normal
They say C3 is slightly larger than normal. So I wonder if I can use Cn rather than C3 in the hub.
Thank you.
Make him an offer? - he has the ceramic version of the bearing you're looking for (2nd image)
https://bikehub.co.za/classifieds/item/road-bike-hubs/1865/ceramic-bearing-full-kit-for-american-classics
