I set up my bike on the computrainer with both the PowerTap and Ergomo devices on it.  I then used the computrainer in ergo mode to step power 50 watts every 30 seconds from 150 watts to 350 watts.  These are the results, very close!20061027_075442_Ergomo_Calibrat.GIF
Bruce what is the reading interval settings between the two. It would appear that the Computrainer is averaging the readings.
Ergomo is set to 1 second, I think the powertap is 1.26 seconds (fastest sample rate possible)
I'm not showing the computrainer data, just using it to provide a consistent load.
If I'm reading the graph correctly' date=' it looks like the Powertap is a lot more sensitive.
Ergomo graph is definitely smoother - not sure if this is good or bad.  The display also doesn't fluctuate as much as the powertap.
If I'm reading the graph correctly' date=' it looks like the Powertap is a lot more sensitive. [/quote']
PT display can be set to update slower (smoother) if I recall correctly.
Yes, it can - but it appears that the Ergomo curve is smoother is well, so not sure if the ergomo is less sensitive, or if it is smoothing the data?
Anyway, I need to run alonger test so that I can compare the NP of the two - that is really the important test from a training perspective.
Must say though, that the NP reading I had on the display the other morning was within a few watts of what CyclingPeaks gave me after the ride.
Yes' date=' it can - but it appears that the Ergomo curve is smoother is well, so not sure if the ergomo is less sensitive, or if it is smoothing the data?
There certainly look to be less data points shown on that graph - need to look at the sampling rate of the Ergomo as any smoothing should be done at review stage in CP ?
Might be something on CF.. Geek
No, exactly the same number of data points - definitely.  Either smoothing or not as sensitive.
Have posted the same graph on CF - thrown it out to the wolves so as to speak!!
Found this..
"Currently, the Ergomo records data every 5 seconds. The Ergomo takes between 72 and 144 measurements per 1 rpm, averages this number over the amount of rpm's per second and saves it. Every second a sample is taken and then 5 seconds (samples) are averaged and this is the number that is recorded in the computer for download. For example: 300w, 300w, 300w, 305w, 310w, will be taken by the computer and the average of these will be recorded= 303watts."
No, that is the old ergomo, the new one is every second here is a sample of the data
0.105 150 184
0.126 163 151
0.147 167 155
0.168 167 163
0.189 162 162
0.21 159 156
0.231 158 163
0.252 159 151
0.273 181 153
0.294 183 205
0.315 184 164
0.336 183 165
0.357 163 159
The first column is time (in minutes) and equates to approx 1 sec intervals, the second column is ergomo watts and the third colmun is powertap watts.
