Hi all
I have an old family bicycle that has been floating around the garage for over 20 years! From what I am told it was purchased round about 1945 by my grandmother. It is unfortunately in a bad state with a lot of rust. I guess it will require a complete strip and respray.
I basically want some help on where to start. I want to try and save as much of the original parts as possible.
How do I go about stripping all the rust and paint to start over? I hope the photos are attached.
Any advice will be appreciated.
Henry
Its called a " Complete Nut and Bolt Restoration " Document everything as it is on photos and video . . Start at one end and strip off the parts putting each section in containers carefully marked ie " Front end fork " ' Back brakes " Cranks and pedals " .etc .Then decide whether parts are restorable  or need to be replaced with new . . Keeping it  original will always keep the value higher .. If original parts are still available it makes it easier to complete the project . Good luck and enjoy the journey .
I used a product called Plascon Removall a few years ago, to remove 30 years of rust from a frame. It worked well and rinses off with water. It's an ambitious project. Good luck.
