Good day. If I have a 26 inch bicycle (Scott Tampico) am I able to change the wheel size to 29 inches on the same bike?
No... You may be able to put 27.5, but definitely not 29.
I had a Scott Montana. I am sure it's the same frame as the Tampico. I put 27.5 wheels on it.
The Tampico had v-brakes. If you upgrade to bigger wheels you may need to change the brakes to discs as I'm not sure you will find 27.5 wheels with rim brake surfaces
Edited by Eugene
