Morewood Dropper Seatpost 30.9mm 125mm Drop External Type Air pressure?
the lyne ones are around 190-200psi so id say start with anything around there?
EDIT: was about to say that your weight on it has nothing to do with the pressure i think...they lock out once extended...atleast the lyne one does. The pressure only dictates haw well it comes back up again after being compressed...so as Bageara suggested....if it is sluggish, pump it until it comes back up nice and fast.
Edited by morneS555
  On 9/10/2020 at 8:06 AM, NeverNotRolling said:
Wow you can get almost anything on Takealot nowadays. Came across Bell motorcycle helmets the other day on there and they're cheaper than most stores, understandably.
Huh?
