Charl AFAIK the talas is a separate tube that houses the airspring therefore I don't thi k your form's stanchion has the dimple needed for you to fit the standard float airspring.
I might be wrong but doubt it
You should be able to buy a float air shaft and you will also need a replacement aircap assembly. Best is to take to stoke or robbies or similar suspension repair shops.
Edited by Eddy Gordo
O, and I should ad, that you will need a specific air cap assembly to fit your csu. There are so many variants. I have a spare one for a 36. When you find out your measurements, then let me know and we can see if it is what you need, if you do not ge/find the right air ca assembly. What year model is the fork?
That's a rare beast. I've got one, but it's a 29" — dm me on the 11th when I'm back at wiel and I'll see if I can source one.
