Shimano Bleed Kits
skycolour213
Its basically a syringe and a funnel. They not very expensive, easy enough to get and the bleed is straight forward.
If you desperate and have some mineral oil, you can use one syringe with the tip trimmed to about 5mm long and plunger removed as a funnel and another syringe with a length of irrigation pipe on the caliper side. (I used a skewer to block the funnel hole when removing it afterwards to stop oil leeking)
