Hi,
I have an Edge 520 paired with an iphone 12 mini.
During my rides the edge just randomly's disconnects from the phone and then reconnects.
The livetrack never works, maybe 5 mins or so and then nothing.
Does anybody else have this same combo of devices and issues ?
I can't find anything on garmin forums really, some people have the same issue but no real solution from garmin is forthcomming.
I dug and EDGE 25 out of the closet this morning. Livetrack worked perfectly.
I gave up on my Garmin 945 with the iPhone, it just never worked. Reboot, reinstall, repeat whatever. The 5 minutes of hope with each firmware update that turns into disappointment..
Since I switched to a Samsung S21 it's been perfect all the time.
Edited by Showtime
I've got a 520 paired with my iPhone 8, both on latest SW versions. Livetrack works as promised, starts automatically and for 99% of rides stays connected the whole ride, although now and again on a MTB ride it does disconnect if we go through areas with poor mobile signal.
In December I got taken out by a taxi and the Garmin/iPhone combination informed my emergency contacts perfectly even though I was unconscious at the time. Grateful for that!
It wasn't always like this - a couple of versions back of Garmin SW I found Livetrack unusable unless I manually started it for each ride.
Yo, that is a proper good advertisment for garmin and the incident detection.
I found a random article somewhere on the internet that says the garmin edge has a weird way of handling the storage system. If your storage space reaches it's capacity by way of all the activities and course etc that you accumulate , it frees up space on the fly. This causes some issues appartnley and manifest itself in weird ways.
so i formatted the garmin in windows, FAT fily system with GARMIN as the device label.
Initial testing has some promising results...
This sort-of-solution has no explanation for the android / garmin combo though.
Anyway...worth a try if you are frustrated and confused like i am.
