Hi guys
What sealant would you recommend for a hot and humid climate? The guys here recommended a water based sealant but my tires are already dry and deflating. Any advice?
Hi guys
Back in the desert? I'd guess your choices are pretty limited unless things have changed substantially since I was there.
That said, I doubt the temperature will affect your sealant that much - a tyre is a closed system, so nothing will escape unless you're letting the air out. Just check levels more often than you normally would and you should be fine.
Brunei this time. The guys at one of the bigger shops put in some water based sealant but it had dried out super fast. Apparently the Muc-off sealant works well so I’ll give that a go.
