I need to move my pedals out slightly, so was on the hunt for washers.
i believe the pedal axle (including thread) is about 14.2mm. so would need a 14.5-15mm internal diameter.
I finally found M14 washers in a 3mm width, but need to bore them out slightly to get them over the thread.
it seems M15 is non-existent and 16mm is way too loose.
can anyone recommend a place in the CT northern suburbs who could help, or if i should rather get some laser cut?
thanks
thanks
My bike shop just gave me a few actual pedal washers from the mechanics drawer - ask yours because it seemed like it was a common item - 3 little spacers each side and problem solved in my case
thanks
If you don't find some at your local bike shop you can bring it to my workshop in Brackenfell sure I'll have a drill bit 14.5mm. You won't find a 15mm washer as it's not a standard size.
PS. It's going to be hell of expensive washers if you have it Lazer cut.
Edited by Me rida my bicycle
thanks all for the info.
i feel so dof, i never even considered a bike shop. at the fit, i was told to get 2.5mm from a hardware store and try 1, then 2 for the ideal fit. so was fixated on getting from a hardware store.
managed to get a 14 today, and learned that if you get 2 from a shop, they are free. if you ask for 10, you pay R75 :)
added a couple to each bike and at least the look axles have a bit more thread than shimano (or so i have read). should keep my heels from the stays.
@Zebra i have been looking at those for a while. they could well be a long term solution on the road bike, so will see what the Fitter says on follow up and may give you a shout if yours turn up. there are some on https://gpm-sports.co.za/cube/bikefit-pedal-spacer-20mm-solid-pair.html, they're just helluva pricey.
Yes, not inexpensive, but I remember paying like $40 15 years ago - they were pricey even then, b-u-t solved a problem, elegantly, quickly and reversibly!
Cheers
Chris
