I have just got my first set of tubbies and the manufacturers range is 8-14 bar pressure which is very wide. What sort of pressure should i be using?
how much do you weigh because i weigh 64kg and i ride on 10 bars there is less rolling resistance but if yuou looking for comfort on that tubbie look at about 9 bars
also if it feels squidgy then pump it up harder you dont want it to roll and also dont be scared of the glue but also dont put enough on so that the glue helps it fall offturtlek2008-09-17 02:55:22
Doesn't really matter what you weigh.... the point of tubbies is to run em fockin' hard...
untill you get a piece of glass in the road and the explosion sounds like 45 magnum in a shooting range smiley17.gif
You and everyone else around you then tries to equalize their ears for the rest of the day.
