By unstuck I presume you mean that the bond between the tyre and the rim has opened up. This happens when the tyre loses too much air and is flattened. The sealant you are using is probably useless now and you need to refill with sealant, and reinflate the tyre. Usually it needs a blast of compressed air to reinflate. You should also check the rim for damage.
The valve leaking could be anything. It could be the valve itself or the seal where the valve is inserted into the rim. If it is the valve (presta) in my experience it can't be fixed and you need to buy a new one.
If it is not the valve itself, using a bit of silicone around the where the valve goes through the rim asually sorts a leak out.
By unstuck I presume you mean that the bond between the tyre and the rim has opened up. This happens when the tyre loses too much air and is flattened. The sealant you are using is probably useless now and you need to refill with sealant' date=' and reinflate the tyre. Usually it needs a blast of compressed air to reinflate. You should also check the rim for damage.
nah, usually it doesn't. A normal stand-pump does the job. A friend of mine (a pure boer machine) always does it with his little hand pump Smile
Thanks for the feedback guys. It is a presta valve. I have filled the tyre up with new sealant and tried to re-inflate it with a foot pump. It still leaks all over the place. I have stopped pumping when everything starts leaking out. Should I just keep pumping till the leakage stops? I shall try the silicone sealant around the valve tomorrow.
And yes, it is a rim strip with a valve.
I have on more than one occasion had the experience that the valve starts to tear out of the rim strip, it is then impossible to get it to seal. Replaced them with a BMX tjoop ghetto conversion myself .......
20081002_134356_Kaput.jpgBigBen2008-10-02 13:46:23
If you have a rim strip I am with BigBen on this. Get a ghetto conversion with a 20 inch tube. I have a set of those on my one Mtb with Mavic 317's and it hasn't failed in more than a year.
