 - has anyone changed their own battery on a 720 or similar model with all the gimmicks (including Altimeter), the battery p/n is 2453. Would like to know if and where anyone has managed to buy one of these batteries.
I usually change my own battery but seem to have a problem finding this one, and do not really want to send it in for the battery to be changed by Polar.
Unless your Polar is out of warranty period, it makes no sence not to send it in to Polar.
Their service is mostly very good, just contact them before you send in your HR monitor, and sort out the fastest way of getting it to them and getting it sent back.
Dick - Fine print in 20 languages excpet engleesh..smileys/smiley2.gif plus I dont plan to swim with it, (probably will sink with it).
Safest bet would be to send it to Polar I suppose, but I would like to see what's what inside as well..
I have taken it to 2 polar dealers here in good ole Schweiz...
1st one gave me a form to fill in and told me to send it to polar myselfsmileys/smiley32.gif
The other said I can bring it in to them and that they would send it to polar on my behalfsmileys/smiley32.gifsmileys/smiley32.gif +/- 2 weeks delivery.
Tried a few watch and electronic shops for the 2453 battery, no luck never had it in stock. It is a larger than normal dia and thickness than the usual batteries, perhaps a camera shop??
I sent my s720i to polar and I think it cost R120.... the Add...... is something Halfway house..... JHB
Rather be safe than sorry.
I know the speed sensor bat. can be changed by a jewler.
Polar dealers are IHF in Midrand Tel: 805-1028
I have dealt with them twice and have only had the best service both times.
 he he smileys/smiley36.gifI found "some" batteries for the 720 - CR2453's nogal, just one problem - cannot buy 1 battery, have to buy a box of them, not sure exactly how many in the box or how much (was in a cataloge showing only the item number).
So it's now in the post to Polar Switzerland.
guys, you are forgetting why it needs to go to Polar , they replace the waterproof seal as well ! this gets damaged in most cases when the unit is opened..
Ja Ja - I so far have managed to keep my hands above the water line when I cycle. smileys/smiley2.gif
Point to send it in is without doubt the best solution.
but
I originally asked the question to find out if anyone had done it themselves, to see if the 720 was more difficult to change than the other polars without the altimeter, temp sensor. Usually they can be changed without damaging the seal (unless it was damaged when last assembled), have done it many times on my other polars and they (I used them for swimming) never leaked, it just takes TLC - just like when you shave your legs?.
