Managed to snap my front derailleur yesterday afternoon.
never kept the receipt
1 x Record front derailleur : R1600Ouch
lesson learnt : priceless
wolfie,
any shop running a computer system will be able to track your invoice and reprint you a copy. not that difficult...
Was going up the flat end of Klapperkop, past Monument park golf course toward the water tower when it happened. Fortunately managed to freewheel most of the way back to  LBS.
Better now than 16 Nov
Guest Agteros
<Hi Jack>
On the topic of receipts.... here in my valley the LBSs have a tendancy NOT to give receipts when purchasing items (large/small/cheap/expensive). Make sure they state what you receive as well, not just a cafe slip with amounts on it!
<Bye Jack>
# Geographics areas, and LBS names, etc withheld to protect the ignorant
Hoe op aarde "snap" jy jou voorste derailleur?
As hy van pewter gemaak is maklik!!!!!!!
wolfie' date='
You would think so Fand, unfortunately shop changed ownership and name in the last 14 months, previous record keeping up to maggots.
wolfie' date='
thats their problem not yours. if they cant reproduce the original, get them to issue you a new one. If SARS walks in there tomorrow, they dont give a sh*t about ownership change. they want paperwork.
a lawyer will get it out of them quickly
Hard luck Wolverine; I saw some pro bike on cyclingnews.com where they were using the Chorus steel FD instead of a record one, apparently stronger than the carbon schmarbon...
Why does no one ever believe that I am stong?Confused
Put you should not peddal with your derailer, especially if you are stong smiley2.gif
Why do you need the receipt in any case?  Surely the S/N is easy to trace at the wholesaler.  Those thieves keep a record of every serial number of every item they sell, to avoid mistakenly sorting out warranty claims on parallel imports.
