 Race:
Duration:  2:17:23 (2:17:24)
Work:      1958 kJ
TSS:       175.2 (intensity factor 0.875)
Norm Power:289
VI:        1.21
Distance:  91.523 km
MinMaxAvg
Power:       0917238watts
Heart Rate:  74171140bpm
Cadence:     3715984rpm
Speed:       078.740kph
Attack on Witkoppen:
Duration:  04:36
Work:      101 kJ
TSS:       11.5 (intensity factor 1.223)
Norm Power:n/a
VI:        n/a
Distance:  2.54 km
MinMaxAvg
Power:       112876364watts
Heart Rate:  130171164bpm
Cadence:     5811483rpm
Speed:       21.244.633kph
TT to Finish:
Duration:  01:00:35
Work:      1007 kJ
TSS:       83.5 (intensity factor 0.909)
Norm Power:300
VI:        1.08
Distance:  40.415 km
MinMaxAvg
Power:       0638277watts
Heart Rate:  117166156bpm
Cadence:     3913882rpm
Speed:       9.478.740.1kph
Check out that TT to the finish, solo at 40.1km.h!!  Eish, and I was hoping it got easier now that I'm turning 40 Cry
Looks like the Vets had a not so hectic ride? Then again I forgot he's lighter than me so he's power will seem lowerEmbarrassedMarius2008-11-17 02:44:42
Okay, here's a little exercise for you.  Take the avg power in his attack, divide by 63kg (to be on the safe side).  Then multiply by your own weight.
Now, try do that power for 4 minutes, then immediately do 1 hour at 0.9 intensity factor (90% of your FTP)
That's what it takes to solo win a race like that!!
if his face was anything to go by, he was simply cruising along with zero effort... LOLLOLLOLClap
as for the rest of them - i dunno... they were too far back so after getting him safely to the finish line i just headed off to go sort out some taxis in randburg area...
that last TT is impressive - If of 0.9 -- so his FTP should be round about 320?
or 5.2 W/KG?
Yup, he's not quite at his peak at the moment.
if his face was anything to go by' date=' he was simply cruising along with zero effort... LOLLOLLOLClap
James Lauter (sp?) doing the commentary on the line got a bit of a surprise when Andrew arrived, nearly missed him!
Belive me, 0.9 Intensity for 1 hour hurts, he just hides it well.
or 5.2 W/KG?
Yup' date=' he's not quite at his peak at the moment.
Bruce, i speak under correction...but does Andrew not ride with a group from the Engen garage in the mornings?  If that is the case, how would he be able to train his L4, L5, L6 zones if he is in a group?
or 5.2 W/KG?
Andrew rides L4, L5 and L6, the group chases him around Jozi...
huh?!?!?!?!?!?!??!?!??  a big yellow bike with yellow headlights and hazzards on and strobes flashing away and hooting like mad and revving it's loud pipes comes tearing up and peels off into the "official cars" turn off at insane speed (almost seeing her @ss in the process) and he nearly misses the fact that there is a winner about to cross the line??????? eish, next year i'm fitting a mega-loud horn as well!!!!!!!
or 5.2 W/KG?
ConfusedConfusedConfused, sheesh!!!  Glad i don't live in Jozi....must be "fun" when you roll through and Andrew is next to you.......ok, i am gonna do a quick 6min L5 interval......1 x new handle bar tape and carbon bar when you get homeLOLLOL
or 5.2 W/KG?
That's pretty much it.  Andrew just rides hard and then he rests.  I've tried to get him to do intervals, but usually just get a not so polite F.O.
He does L5/L6 in the various hills on the route, and everybody else tries to hang on.
ConfusedConfusedConfused' date=' sheesh!!!  Glad i don't live in Jozi....must be "fun" when you roll through and Andrew is next to you.......ok, i am gonna do a quick 6min L5 interval......1 x new handle bar tape and carbon bar when you get homeLOLLOL
That's why it is well documented that you don't half-wheel him, he just goes faster! Ouch
