BMG, was there another threaded nut covering the main one?
looking something like this
http://www.ukbikestore.co.uk/product_images/Medium/D30070BLK;Warehouse;Warehouse.jpg
Becasue if so, then your cranks are similar to the Race Face X-Types and one can use the cap nut as a self extractor.
Hi guys, thanks for the replies! Guess I will need that tool then.
Patches, this is how the nut looks like
http://www.winstanleysbikes.co.uk/images/prod_52575.png
Looks like that outer one is a 10mm and the inner inner one 8mm.
If I am right, then it self extracts.
yup! does look like a self extractor!
So BMG, in that case, leave the outer one on. Use your 8mm hex to undo the inner one until it pushes against the outter nut. then continue to loosen the inner until crank pops off.
If there is no outter nut and just an inner crank bolt, then you'll need the tool
