What to look out for when buying a 2nd hand bike?
I'm buying a second hand bike from Avron's on Friday. I've already seen the bike and there's nothing glaringly wrong with it, but i was just wondering whether there were tricks to finding stuff that might be wrong with the bike that isn't so obvious...
agreed! get a chain wear tool. If the chain is really stretched, and the gears seem to shift fine without jumping, then there is a good chance you will need to replace the cassette, blades and chain, which can be costly.
Frame! Check the welds for any signs of fatigue. Make sure the wheels run true. If its an integrated headset turn the handlebars from side to side and make sure that it turns smoothly. If this is gone you might as well toss the frame.
