First flat wheel in a verrrry long time!!!!!
Ok we have been riding the MTB tandem since 2005 with slime in the tubes. We now have el rapido here with 28c wheels on. This morning we went over a duwweltjie and the wheel was flat almost immediately. I remember them saying that slime will not seal a road tyre due to the higher tyre pressures. It needs to be below 4,5 bar to seal. If I put slime in the tube will it deflate and then seal when it reaches +-4,5bar??????? 4,5 bar is better that FLAT?????? If we are close to home 4,5 bar will get us there. If we are travelling 35km/h 4,5 bar in the tube will be better than flat?????
They said that you inject the slime into the tube and then put a patch on. Does this work???????
  Quote
Ok we have been riding the MTB tandem since 2005 with slime in the tubes. We now have el rapido here with 28c wheels on. This morning we went over a duwweltjie and the wheel was flat almost immediately. I remember them saying that slime will not seal a road tyre due to the higher tyre pressures. It needs to be below 4' date='5 bar to seal. If I put slime in the tube will it deflate and then seal when it reaches +-4,5bar??????? 4,5 bar is better that FLAT?????? If we are close to home 4,5 bar will get us there. If we are travelling 35km/h 4,5 bar in the tube will be better than flat?????
Hendrik, I cannot vouch for slime in road bikes. However, I'm quite good at fixing sticky keyboards. I once spilt Coke on my keyboard and the ? key was just as buggered as yours. I took the keyboard apart, separated the plastic membrane from its underlying contact board and simply dunked all plastic parts in a sink full of soapy water and washed it. After carefully drying it by shaking it and leaving it in the sun, I put the whole thing together and voila! No more sticky keys.
  Quote
  Quote
JB will it work on chandeliers??
  Quote
  Quote
I did it once with a Rubic Cube....... pulled off all the stickers and repasted them so it looked as If I solved the puzzle. Nobody could do anything with the cube afterwards and it even kept the boffins busy for days on end!!!!!!!
PS lees my signature!!!!!!
  Quote
  Quote
  Quote
How the hell did you get coke on your chandelier........ oh, now I know, you sneezed...... en Johan hoekom het jy nie die coke sommer uitgeblaas nie...... wou jy die evidence vernietig...... mmmmmm?????????
Tom Boonen sal julle amateurs noem!!!!!! teeee heeeee!!!!!!!
  Quote
Touch?  LOL
Maar ernstig nou Hendrik. Gaan stadig met daai vraagtekens en uitroeptekens. Hulle maak ons oe" seer.
PS - dit was eintlik Fanta ek sweer.
  Quote
Stay on topic guys...damn' date=' some things don't change if you wander off to the desert for a few days LOL
Fatmod
Ok, yes, bigH, slime does work in road tubes. I have used it in such. I have not tried the needle and syringe method, rather the more messy via the valve method. Note, I said messy, but it does work.
  Quote
  Quote
toyophilia?
You know you reporter okes....... always twisting words!!!!!! Netnou kry jy 'n koppie tee in die gesig soos Steve H gemaak het met daai Huisgenoot Tannie wat sy huwelik opgebreek het!!!!!!
Fatty glad you are back..... I thought you deserted us!!!!!!!!
  Quote
  Quote
Touch?  LOL
iemand het jou fanta met coca cola gespike?Confused
  Quote
  Quote
How did your chandelier get sticky?
In a failed attempt to do a "Half turn Errol O'Brien" while swinging on it!!!!!!!!!!!!!!!!!!!!!!
There's something up with your banter.
