Ok, I've got a 9speed Ultegra groupset with FSA Carbon cranks.
Can you buy "pieces" and get it to 10 Spead?
I don't want to buy a new groupset? I will have to give away the carbon cranks if I re sell.
What is the best option?
I cannot go to campy as I got 4 sets of shimano wheels, shimano tools etc.
TitusTi - do you even need the new rear der?  The rear der goes where the STI's tell it to go, and I would have thought that with the narrower 10 speed cogs the 9 speed der would have sufficient movement to cover it?
(Not trying to be overly clever here, just asking the question.)
TitusTi - do you even need the new rear der?  The rear der goes where the STI's tell it to go' date=' and I would have thought that with the narrower 10 speed cogs the 9 speed der would have sufficient movement to cover it?
Sorry MD, forgot the chain.
I suppose you don't really need the rear mech.
4 sets of shimano wheels...
That would require you to buy 4 cassettes ....unless you swop cassettes when you change wheels..Confused
Might you also not need hubs as not all 9spd hubs can take 10spd. I know when i changed my cluster from 9spd to 10 spd Cyclelab had to check first if my hub could take it .
the answer is in your post.....
