I would like to replace my stock Juicy clean sweep rotors (160mm) with the Hope Floating Disc rotors (183mm). Obviously I would need an adapter but that's the least of my concern.
I have heard that the rivets on the Hope's catch on the Juicy calipers which renders the match between the two incompatible.
Anyone have this problem or has anyone managed a work around ?
Thug, just get Hope calipers! You know you want to Wink
I think these purple limited edition ones will go really well on your Scandal!
Zaskar2009-07-01 01:34:15
Cant comment on the bolts, but make sure that the width of the braking surface match up with the width of the pads! Not too much of an issue if the braking surface is wider than the pad, but the other way round is a big no!
Ok, I'll use pictures. LOL
Green circle on rotor = rivet
rivet comes into contact with green circle on caliper
If its true, is there a work around or do I need to sell my Juicy Carbons and buy a set of Hopes ?
ok seriiiaaaaas hijack here. Thug' date=' is it critical that the spacers shown on that juicy picture are placed like that ?
Yup, otherwise your spacing will be all wrong and the caliper won't bite the disc in the right place.
oh smucks! lucky it's on someone else's bike.
As droo says.
Guest Big H
Get Hope calipers..... you will not be sorry. I have Hope Mono 4 disks with 180 mm rotors on the MTB Tandem...... they are super!!!!!! Got them form www.chainreactioncycles.com
