I need to replace the FSA chainrings on my bicycle shortly. I've got a Ergomo on my bike so changing the whole crank and bb is not a option. Will Dura Ace chain rings fit on the FSA cranks or must I replace with FSA?
Guest Big H
Try Boy Private Mail me with your email adress included and I will email you the Barnes Cycling Manual regarding Chainring. You will find all the answers you need in it. BBB makes good replacement Chainrings.
Great there is only one way to go put Q Rings on. The 130bcd which is basically the Shimano Bolt pattern it fits FSA and Shimano.
Q rings are oval chainrings giving the right power in the right place, easier riding and great hill climbing.
If you want to know more search the hub for comments on qrings.
The road dble set retails at R1500.00 for a set
