well done on 1000!!!
Thanks! Starting to think I should do a bit more work though...
does that use a CVT system?
Nope, just a belt drive. One gear's all you really need on a commuter.
I want one' date=' Imagine how quiet it must run..[/quote']
Nearly rode into a guy in Jonkers on a Salsa 9'er with a belt drive - that thing was so quite, then again that guy also looked like he was a easy jaunt the way he was cruising up the trail...
I think you can get Rohloff hubs with a belt spline add-on....Then again thinking is sometimes assumptions.........
You can't break and rejoin a belt, so the rear triangle has to be splittable. Other than that, it's pretty much a standard arrangement. The stand - didn't see much that was odd about that.
