What type of brake pads am I looking at for the avid juicy 5? The LBS told me that I wont find the originals and BBB makes some but I wont get them before January. Any other brands?
Well I suppose if you can only get BBB in Jan then any brand will have to do for now . It is not so much he brand that you should be worried about but more if it will be metal or synthetic pads . One brakes better but does not last long , the other ones (metal) does not brake as well but last 10 times longer .
The bigest difference between metal and resin is the following:
Resin less noise
Resin good in dry, *** in wet
Metal lasts longer
Metal prone to noise
Metal good in wet
Metal last longer
Resin handles heat well
Metal fades with heat
Depends on your weather conditions. For me living in KZN: Metal Summer, Resin Winter. IE Resin=Dry, Metal=wet.
