After a very rare blowout I had to put a tube into my much beloved Stans conversion . Back at home I immediatly set about converting back . But this time it was a real struggle . The thing would just not seal . After staring at the problem over a few cold one it came to me that maybe all the old Stans on the rim tape and tyre may cause it to not seat properly .
Trying to get this stuff of with Kleengreen , water & soap , Castle lager or tip-ex did not work . So I grabbed the Turps bottle . It cleaned everything and after a water wash all looked as good as new .
After fitting everything it was of to the compressor again , and as you may all have guessed another Stans conversion was performed .
The End
Thanks, might just help me this weekend! I had a puncture at Winter challenge and put in a tube. I want to remove the tube and redo the tubeless this weekend.
Will keep this tip in mind!
Seriaaaas !!! It is not a banned sunstance or anything ? My neighbour complain about the cops raiding my house once a week !
Where will I get this oil ?
dirt-rider try to use eucalyptus (spelling?) oil next time' date=' its better for your sinuses than turps.[/quote']
DR - just make sure that oil is Koala bear friendly Wink!
I cannot believe I just typed that... Embarrassed
RodTi2007-07-12 05:16:16
