  • Replies 33
howzit guys anyone kow why my carbon frame is creaking when i put a bit of power through the pedals. is it normal? i am 95 Kgs
at the crank/bb ? dual or hardass ?
Check your BB cups are greased, then check your skewers for tightness, then grease the dropouts a little.
Also check your chainring bolts, put a drop of lube on those to see.
Do one thing at a time and test so you know exactly where to go next time it dries out.
The carbon is not creaking.
I dont want to be a prophet of doom, but I couldnt find the "creak" on my bike and it ended up being a crack on the rear stay. It was not easy to see. Check it out carefully especially where your rear disk brake connects to frame. Or if its a road bike then check whole rear stay for hairline cracks.
Make sure the pedal axles are greased where they screw in to the crank arms. My carbon fiber road bike was creaking/ticking noise and I finally solved it by greasing the pedal axles.
I have the same thing on my bike.
Checked the frame, oiled every thing. but it is still there.
Not your knees?
Does it creak when you stand up as well as sit or only sit?
Grease the seat rails, if that does not work, put some grease on the fork stays.
But it is not the frame. Something just needs some lube or grease.
OR
If all else fails do what I tell everyone to do
Buy a set of earplugs.
