I want to know why after a ride starting and finishing at the same spot that the ascending and descending figures don't match. Surely if you ride downhill 200m you need to climb 200m.
How far out is it usually?
Where I ride is as flat as a snooker table, there and back ride of 33,5km as a speed trial. But my Polar indicates altitude gains of from 0 to 50m on different days. I think its got to do with the temperature variance during the ride affecting the barometric pressure, which is how the Polar measures altitude.
My Polar CS600 always under reads by 10-15% when compared to GPS units. This is probably due to the recording interval and the relatively slow adjustment cycle of the barometric units. I am sure that GPS units are more accurate.
temperature changes
Garmin Connect has an Elevation Corrections option for each training session that you upload. I ride a loop on Manning Road and the elevation at the same points gradually increase (generally) during the training session:
Enabling Elevation Corrections fixes the elevation data:
Might be handy information for the Garmin owners out there.
Cheers,
Andrew
