  • Replies 46
seems further than it is COis! and if you dont make it there is so many lifeguards around you would be okay...... dont think along the lines of baywatch lifeguards but they will save your life :clap:
I will rather drown than be helped by David Hasselhoff :)
I might try to do a bit of swimming and see if I can do that. Think the estate has a round swimming pool of 3x3 meters to practice in :). The running is also a problem. I am way out of training in regards to running since the last tumble I took over a rock at night :D
i think the closest to this is the grabouw xterra andy
Tx faceplant. I might enter the "lite" one for the sole reason that I'm a bad swimmer. But I see it's on the same date as the CA2C. Choices... Ok I should probaly end the hi-jack here!
Buffeslpoort is the week before 70.3 :(
Roodeplaat is the week after the Troisport City Triathlon :(
come on thug you dont need a week to recover from the joburg tri?? maybe the wallets do but we will be fine :lol:
