Lights Lumens and what not
Bike Lore
Illuminance(LUX) is a measure of how much luminous flux is spread over a given area. One can think of luminous flux (measured in lumens) as a measure of the total "amount" of visible light present, and the illuminance as a measure of the intensity of illumination on a surface. A given amount of light will illuminate a surface more dimly if it is spread over a larger area, so illuminance is inversely proportional to area.
One lux is equal to one lumen per square metre:
1 lx = 1 lm/m2 = 1 cd·sr·m–2.A flux of 1,000 lumens, concentrated into an area of one square metre, lights up that square metre with an illuminance of 1,000 lux. However, the same 1,000 lumens, spread out over ten square metres, produces a dimmer illuminance of only 100 lux.
Achieving an illuminance of 500 lux might be possible in a home kitchen with a single fluorescent light fixture with an output of 12,000 lumens. To light a factory floor with dozens of times the area of the kitchen would require dozens of such fixtures. Thus, lighting a larger area to the same level of lux requires a greater number of lumens.
As with other SI units, SI prefixes can be used, for example a kilolux (klx) is 1,000 lux.
  • Replies 96
All I can say is that the lights I purchased from Brighter-Lights made fellow riders in this year's Trans Baviaans 24 hour think a space ship was coming up behind them to land :D
I don’t really want to get in to a Lumen vs Lux argument.I agree lumen and Lux is a very confusing concept. More so when one mixes the points of interpretation. :drool:
The way that I understand it may be wrong but it worksand I have made a lux meter so I have grasped some aspect of it. It may be skewed but it works for me. In short as I understand is Lux which is a Lumens / area measurement http://en.wikipedia....iki/Lumen_(unit).Looking at it form a math point it is Lumen = Lux* m^2 which if you remember for school is like integradeing dx/dy if you sum all the points over the area then you get lumen.
Looking at a lux meter there not using a 1sqr m sensor . So there making assumption that intensity at that point of measurement is the same as the area. That is where the point comes in.
I think of it like Acceleration is the derivative of Velocity over time which is the directive of Distance over time.
Lux = Lumens over area.
Mathematically, 1lx = 1 lm/m2
yes. pl had some gr8 ideas. but it was bound to happen. that it will get cheaper to buy a light than to DIY one. just economy of scale. I like your light buy the way. H
my first light was a Princeton Tec Switchback 3 it cost me R3500. produces about 270 lumen and weighed 1kg. it was more than enough light really but having x10 more is not a pain
LEDs getting cheap
Still have my Sigma Evo 5w with the Pb battery.
  • 2 months later...
  • 2 weeks later...
  • 4 months later...
