hoe werk daai tape wat runners op hulle bene plak? weet nou nie of dit nou reg uitgekom het niebiggrin.gif
wat noem mens die tape?
ek sit met 'n hamstring injury(right side) and strained it even more with the lourensford classic
also got a very bad cramp in my left calve, calve muscle kinda sore now after daai een
the thing is: i have the gun run 1/2 marathon sunday en ek moet nou 'n plan maak
for the calve issue: falke compression socks?
hamstring issue: some of that tape??
  • Replies 34
Back out of the run. You'll only make it worse, and require longer recovery time. Listen to your body.
i'll rather try make a plan
after the run i have 2 weeks before buffet olives... ek sal dan recover??
Kinesio Tape - R120.00 at sportmans warehouse
It's mostly applied by physios. Have you had your injury professionally assessed ?
+1 to pull out of the race. You'll only make it worse.
The product you are referring to is Kinesio Tape. You can buy a brand at Sportsmans Warehouse. I find that it helps with aches and pains (similar active ingredient as Transact Tape as far as I know EDIT: This is not true).
Compression socks will not help with cramp. If I were you I would hit the physio for the week, use some of the tape until raceday and make a call in the morning. If in doubt, watch the Semi Finals!
Edited by gadget
Incorrectly applied tape is not going to help, in fact it might make the problem worse. Get a professional assessment, and have the first tape application done by a physio. If necessary, you can duplicate the position and tension of the tape when reapplying it yourself at a later stage. It's definitely not just a case of taping any which way. Correctly applied, however, it works well for certain injuries, hamstring being one of them.
The product you are referring to is Kinesio Tape. You can buy a brand at Sportsmans Warehouse. I find that it helps with aches and pains (similar active ingredient as Transact Tape as far as I know).
There is no active ingredient like a transact patch. It is purely an elastic tape that offers support.
no have not had it assessed...yet...
so wat is dan al die fuss oor compression garments?? waarvoor is dit dan nou eintlik..always see runners with the falke socks..
I agree with those that said: Assess and Recover, helloise.
Dybeenbeserings moet jy maar versigtig hanteer.
dankie ek weetwink.gif sh!ts..... as ek net oor die gunrun hurdle kan kom sal ek 'n plan maak en terug gan na my biokinetikus
Keep us updated, eh?
Good luck with your decision.
21.1 kms - hmmm....
21.1 kms - hmmm....
will do so, just waiting for the helderberg harriers guys(second opinion)..they are experts in their field wink.gif
True: no active ingredient. Untrue: purely elastic tape that offers support. The tape is designed to promote osmosis and it is therefore imperative that it be applied by a knowledgeable person, preferably a kinesiologist.
