I'd like to upgrade, so might as well take the step to a carbon fibre road bike. While I am hoping to loose some weight, I'm still going to need a bike that can carry around 100kg's. What carbon bikes are best for heavy guys?
If I remember correctly, most Cannondale Carbon bikes have no weight restrictions, not sure about the super light Evo. I also think Giant had no weight restrictions....
As long as you don't go with any of the super light 650 gram frames you will be fine.I have seen how LOOK is tested and you can go up to 120kgs.
Why 'might as well' upgrade to carbon?
What do you expect to gain from it?
I'd like to get faster. And with a new bike I'm also hoping I'll spend more time riding. I've had a secondhand aluminum bike with reasonable wheels for about two years. And now recon I can justify spending some money on an upgrade. From the prices and bikes available it seems that carbon fibre are the better quality bikes. An upgrade to the top of the range aluminum doesn't seem worthwhile as the pricing seems to be the same as a mid level carbon bike.
There is a very, very big oke I know that rides a Trek 5200 OCLV carbon. I have officially dubbed it the Strongest bike in SA. Oke weighs at least 140kg.
With a tandem rear wheel?
Carbon won't make you faster. It'll only enlarge your carbon footprint.
Go steel, it has the smallest carbon footprint of steel/aluminium/carbon.
Carbon footprint as per Ride magazine, Sept 11:
For a 10kg frame:
Steel: 42kg
Aluminium: 72kg
Carbon: 114kg
Titanium: 400kg
I moved from Alu to Carbon, and yes...the gains are noticeable. But......
It does ride harsher
You need to be quite fit for it to make change (an unfit person will stay slow)
All the screws need to be torqued, as over tightening leads to busted frame :unsure:
My Alu and carbon frame are both Merida.
FWIW....I have an old steel roadie bike, 30 yrs give or take, and it is by far the most comfortable bike to ride apart from a full suss mtb
Edited by DaLoCo
My carbon bike is much less harsh than super stiff Alu frames.
Another factor is trying to get a high end Alu frame these days except for the CAAD.
And if you think a 1 kg difference isn't significant than you really don't go uphill much.
My carbon bike is much less harsh than super stiff Alu frames. (lucky you..... don't think the OP is on a super stiff alu frame now)
And if you think a 1 kg difference isn't significant than you really don't go uphill much. (my first line says exactly that....gains are noticeable)
Edited by DaLoCo
bike shops tell me carbon is more robust...
but they were trying to sell me mtb wheels.
carbon more robust... care to tell that to the MTBers with busted carbon BBs?
For the same frame weight, carbon is by far stronger than aluminium. Imo a heavy rider should avoid light aluminium frames.
As for reasons why to upgrade - you don' need any. If you have money burning a hole in your pocket, why not? Don't expect to go any faster, though, unless the you buy a time trial bike, helmet and skin suit ;)
This :thumbup:
