So I have an old Trek in the garage that I want to convert to SS just for the odd commute and messing around. What do I need? Been looking on the net but nothing is actually helping.
And how hard is it?? I think its a 24 speed at the moment.
  • Replies 74
Very simple.
  • remove useless der's and shifters
  • remove cassette
  • drink a beer
  • fit chain tensioner to where the rear der was
  • fit loose sprocket on free hub body loosely
  • shorten chain to fit sprocket and tensioner
  • shift sprocket along body to ensure you get a good straight chain line (Look from behind the bike and get it right)
  • Mark this position on the body with tipex
  • drink a beer
  • remove sprocket and add spacers to get the sprocket on the previously mark tipex spot
  • re-assemble the lot and go for a ride
  • drink a beer and smile
I looked into doing this, I am pretty hands on and do all my bike servicing, but deceided for my SS build to rely on the LBS, I was lucky that my frame had horizontal dropouts so I dont need a chain tensioner. All that was required was to put on a 16 tooth - I could have done this myself, the tricky bit was finding and installing the correct BB (compatible with my Campy c-record cranks) so that the chain-line was correct.
Haha.. Just had a laugh... So i only need a couple parts from the shop?
Which model Trek is it? Rigid fork? Just curious, I also have an old Trek and have been thinking of converting for a long time now.
Similar to this.. Spring loaded fork.. V-Brakes.
Thinking of even sanding it down and spraying it plain with no decals or anything.
Edited by Fruity
