what the title says.
Can I drop in an SLX rear cassette in place of the XT.
I have full XT everything else, just wondered if there would be any issues.
money is a factor, hence the question, else I would just get XT again
alternatively does anyone have a second hand set floating around that is still usable :D
thanks
Edited by geecee
thanks
you can replace the cassette with what ever you can get your hands on, Shimano or Sram as long as its the same speed cassette (9, 10 etc) you can even replace with a deore cassette, will just be heavier and slight different design to the XT
...serious answer... yes you can. As long as the number of sprockets is the same. Heck, you can even put a SRAM cassette on. Try match your tooth count though, or you might have to shorten/lenghten your chain.
thanks
i am running full xt with slx cassette ,no problem(was like that when i bought the bike new)
