Hi Hubbers
Just bought a Selle San Marco saddle with carbon rails.
I'd like to install it but am a little nervous regarding how much torque to apply to the bolt.
My seat post is an FSA team issue with a single bolt.
There is no indication on the saddle and gooogle is giving me mixed answers to this.
Those carbon rails are tough - just snug it up hand-tight enough to stop it slipping. Take a tool with you on the first few rides in case it slips.
I had the same problem with the San Marco Superleggera, it also has carbon rails.
I searched the web and even wrote to San Marco, I never got a reply, I only get their news letter once a month now...
The only good piece of advice I got was from my LBS who said that I should tighten it to the torque spec of the seat post, that info should be easily available.
I found that if the rails aren't tight enough the saddle moves forward or back really easily, so you really have to tighten them a lot.
I have since managed to crack one rail, from riding though, not from tightening. I still use the saddle, but keep an eye on them.
Edited by NitroDoni41
Why don't you also try some carbon assembly paste? It'll let you torque just a bit less, and still hold the rails nicely. I used it on my old seat post that never really gripped nicely. Worth a shot?
Small carbon bits (stems, saddle posts etc) seem to have similar torque specs.
Generally between 5 and 8 nm.
Start at the lower end of scale and adjust accordingly ... 6nm should however do the trick.
I have a similar setup (carbon seat post & carbon rails) but with two bolts and each bolt is tightened at 7nm.
As Chowder says the single bolt types can go a little higher but I wouldn't go over 10nm.
My seat post says 22nm. Have a Fizik with carbon rails and have torqued it 16nm. If I go lower, I find that it slides backwards over time.
22nm.? :eek:
That sounds like plenty torque ...
22nm.? :eek:
Jeez! I will snap my wrench never mind the rails. I torque my seatpost at 6nm and I have to grid my teeth and close my eye. I hate that noise of snapping carbon
22nm.? :eek:
Here is a pic of the EPost
