SRAM 10spd chain and shimano Utegra jockey, are they 100% compatible?
On my road bike I've got a FSA Compact crank, SRAM red 10 spd Cassette, Shimano Ultegra jockey, derailleur, levers and Shimano HG chain.
For some reason the chain makes a "louder than normal" noise
like a RRRRRRRRRR instead of a whirrrrr (kind of like if the chain was rubbing on a sprocket like when you ride with a extreme cross chain) when in certain sprocket selections (Usually when on the 2 or 3 sprockets towards the center of the cassette).
Other than this the gears work perfectly, no slipping and gear changes first time in both directions.
As the cassette gearing option I have is not available from shimano I want to stick with the SRAM cassette but replace the shimano chain with a SRAM chain in the hope that the 2 SRAMS might work a bit quieter together.
So the question is:
Is a SRAM 10spd chain and shimano Utegra jockey 100% compatible?
Personally I don't see why not but want to make sure before I order a new chain
The 10 speed Sram chains are compatible with the Ultegra derailleur. I am not sure if the uni directional Shimano chain will be noisy on a Sram cluster if fitted the wrong way around, just check that the writing on the chain faces outward before you go to the expense of a new chain.
Thanks will do, but I think JA-Q001 has hit the nail on the head wrt to the SRAM red being noisy by construction design.
Looks like if I want the same gearing option that I will have to try either the newer XG-1090 or the stock standard PG1070, there is quite a price difference...SRAM she are not cheap
Found this on the Competitive cyclist website:
"The original SRAM Red Cassette was an exceptional drivetrain component with only one downside: when installed on a deep carbon wheel or ridden amongst a group of riders on Red, it created a resounding cacophony that drowned out even the most concentrated thoughts. There was nothing inherently wrong with this cassette, known officially as the OG-1090. It was lightweight, it shifted crisply, and was resistant to wear over the course of prolonged use. But it was noisy due to its Powerdome construction, which acted like a phonograph that reverberated drivetrain clatter from the freehub and chain. And thus the new SRAM Red XG-1090 X-Dome Cassette was born"
http://www.competitivecyclist.com/sram-red-xg-1090-x-dome-cassette
