I think Zipp makes something like that. But I do not thisnk it's grease, wich is used to make item move easier, but rather a paste so that the parts don't move.
Nee' date=' bel jou bike shop, dis juis daai copper stof in die grease dat dit maak dat dit nie vassit. Hulle het 'n woord daarvoor, maar ek kanie dink. (Something ...dize)
Meeste workshops gebruik dit.[/quote']
waarvoor word dit gebruik ?
As ghries ? soos in die bb ens ?
Of as non-slip soos in die seatpost en waar die stem en die handlebar bymekaarkom ?
ANY GOOD LBS SHOULD STOCK TACX CARBON COMPOUND WHICH IS USED FOR CARBON PARTS. CALL 011 6082003 AND ASK OUR SALES PEOPLE TO ASSIST YOU FURTHER.
PS THE PRICE IN POUNDS QUOTED LOOKS VERY HIGH AS ITS AVAILABLE IN A SYRINGE APPLICATOR AS WELL FOR ALOT LESS IN RANDS
RGDS SM
Copper slip is not a grease to be used in moving parts. Its basically used as a kind of friction reducer in mostly static parts and is used heavily in the auto trade, an example of its use is its put on the backs of disc brake pads to prevent squeaks, or bolt threads to prevent the nut and bolt rusting / corroding together, on battery terminals to prevent corrosion etc.
Why would you need something special just for carbon bits? The idea behind using grease of some sort with traditional bike bits, is to prevent different alloys "welding" together via oxidation, thus siezing them in place, not so? Surely that can't even happen with carbon? J Boringman, please advise.
