I currently have a 2012 Titan 29er Comp, which the spec sheets rekon has a Titan Comp Saddle. The seams on my saddle have started to split, and the saddle will last a short while still but needs replacing.
Looking online at all the saddle options I am overwhelmed as to what to get as a replacement. My 2 requirements at the moment are, affordable ... and have the same profile as the current one seeing as I am used to riding it now. Does anyone have any recommendations of which are the better makes/models I should be looking at ?
I don't want to waste money by buying the wrong saddle as it's not a couple bob that's at stake.
I spend about an hour and half in the saddle daily so comfort would be a 3rd requirement ;)
I used the same FIZIK Tundra 2 on three bikes now and I will use this saddle untill it brakes. Then I will buy myself another Fizik Tundra 2.
You can buy cheap ones on the hub, not sure what the new price is.
