Rockshox Reba travel
BogusOne
How difficult or easy is it to adjust the travel on a Reba dual air fork? Its currently running on 80mm travel but I want to extend it to 120mm for my new build if its at all possible.
Is there any knowledgeable hubbers out their that can guide me or even do this for me and if so what can I expect to pay for this? :blush:
Sorry for posting, I know I read it here somewhere a while back but too lazy to search for it. :ph34r:
Edited by BogusOne
Link to comment
Share on other sites
PM Droo. He's in our neck of the woods and can do it for you if you want to.
Alternatively - simply remove a couple of the travel spacers in the fork. Should be that easy... They're little plastic washers with a slot in them so that it can be fitted onto the slider...
Link to comment
Im very hands on as you know mayhem but im scared I stuff this one up hahaha.... Don't even know where to start to open it up. Taking it apart is what freaks me out :eek:
Link to comment
You can definitely get it up to 100mm with no issues, but there are only certain ones that'll go to 120. Bring it in and we'll find out chop-chop, and it won't break the bank.
Link to comment
Awesome Droo :thumbup: Where abouts are you guys?
Link to comment
In the Cape Town Science Centre in Main rd Obs. Opposite the top of Milton road, across the road from Chippies. 10 - 6, Monday to Friday.
Link to comment
Shweeet. Will pop in some time during the week. Thanks Droo
Link to comment
Easy peasy, took mine's spacer out and getting almost 120mm of travel from it.
Anything specific one needs to know as to opening it up? What tools is needed etc?
Link to comment
My advice, try and take it apart yourself, if all else fails, take it to your LBS with all the parts and let them fix it :ph34r:
Youtube will have a couple of vids on this, but if you do try and take it apart yourself, golden rule - Don't force anything open.
Link to comment
If its QR then the max you "should" take it to is 100mm (so the book says), if its tru-axle / maxle then you can take the second spacer out and get to 120mm.
Not sure i understand the logic but it must have something to do with the strength of the lowers, I've seen other forks running 120mm with QR that never had a problem.
Link to comment
hahahah soos hulle se met geweld kan jy jou vinger in jou hol ook afbreuk ne .... :whistling:
Nah will keep the force to the minimum should I decide to go that route. :thumbup:
Link to comment
I have a 150mm fork with QR and no problems
Link to comment
I'm very tempted to take mine to 120mm but I also like my front teeth.
Nothing a good dentist cant fix Bobbo :lol:
http://newveneers.files.wordpress.com/2011/07/tom-cruise-before-after1.jpg
Edited by BogusOne
Link to comment
LMAO - probably need more than a dentist to make me look that good
Link to comment
