Sram rear hub bearing replacement
dalem44
I don't want to sound like an absolute noob, but how do you take the freehub off?
I think the axle needs to come out first.
Link to comment
Share on other sites
I managed to get the black nut off and I got to the bearing. It was completely dry and needs to be replaced.
Thanks for all the help guys!
Much appreciated
Link to comment
Pull the freehub off and use the 2 nuts marked 3 as your double nuts.
You are in any case going to have to take the freehub off.
To take the freehub off you nee a 11mm allen key. To take out the axle loosen all the nuts and with a small hit from the non driver side the axle will come out on the driver side
Link to comment
Just a tip. Always take photos of the assembled unit before taking it apart. Always help if you struggle to put it back together :thumbup:
Link to comment
Much appreciated
You may as well replace both bearings while you're at it.......
Link to comment
well done on the work so far, interested to see how this pans out
sorry for the hijack but this is why i love hope kit. easy full breakdown service with a rag and rubber mallet only. oh and replacement bearings if needed of coarse.
Link to comment
Seems pointless to do a half job... strip it, clean it, get new bearings, clean and grease new bearings, and install everything again.
And you might as well do the same for the freehub if it is serviceable.
Link to comment
The Hope tools and a blind bearing puller help a lot...... :)
Problem with Hope hubs is that you service them more than they need to be serviced...
Link to comment
This. While you've got it apart just do the whole thing.
Link to comment
