Hi
I am building up a training bike from some spares that I have.
The frame I am going to use has Quick Release at the back. The wheels I intend using are Bontrager with 142x12 through axle hubs. (I think Bontrager use a DT Swiss hub). So what is the best solution to make it work? Do you get an adapter to put in the hub to make it QR? And if so where do I find such a thing?
Hi
Hope has end plugs that can swop between QR and thru...don't know if bontrager has the same.
But yes, that would be you best bet
Need to check the clearance on that frame with the QR as it will more than likely be designed around a 135mm spaced hub..... you might be requiring a new training rear wheel I think
Thanks Hairy. It is a 29er. My first choice would have been to keep the Bontrager wheel as it could serve as back wheel for my other bike in case I need to fit it for whatever reason... But that wheel in the add is cheap enough to consider - just wish it was in Gauteng!
Edited by Superfly1
Hi
This is what you need - Mavic "plugs" that fit into most 12mm TA.
http://www.evobikes.co.za/wheels/wheelset-accessories/mavic-adapters-for-12mm-thru-axle-to-normal-qr.html
  • 2 weeks later...
if it is a 28hole rear bontrager hub , i would offer to buy the wheelset from you :)
Hi KiNgL
I was advised today that the particular hub that I have can NOT take different end plugs.
The wheelset is Bontrager Race Lite. 28H hub. Damn I had the bearings replaced and the wheels run 100% true so wanted to use them on my build project. Seems like I need a different hub at the back so might just consider selling the wheels and getting something that can swop plugs... Make me an offer if you are keen.
Edited by Superfly1
