HI Hubbers
I have a Rock Shox Revelation Fork with a 20mm Maxle wich I need to convert to 15mm in order to accomodate a Mavic Cross Ride Rim.
Have searched high and low for adapters and cant find anything.
Help Please
I don't know too much about DH/Enduro stuff but isn't the 20mm 110mm wide - the 15mm TA is only 100mm wide.
Not sure it can be done....
If the hub doesn't have 20mm inside the bearings, which I don't think it does, then you're not going to find an adaptor. The only kind you get are end caps for the hubs that reduce the ID, not for the forks.
Your other option is new fork lowers, but I think a new wheel will be cheaper.
HI Hubbers
Help Please
Someone correct me if I'm wrong, please - but you're going to have to either get a new fork, swap out the hub for a 20mm, convert the hub to a 20mm (if convertible) or get some inserts machined up for you by an engineering shop. And then you're going to have to buy a 15mm maxle.
Cheaper just to buy a new 20mm hub and build the wheel across, IMO
Ek het n draaibank gekry. ek gaan een of ander tyd begin kyk om goed te draai vir so iets omdat baie mense sukkel met die proebleem. ek het destyds goed vir my self gemaak vir my ander fietse.
