Clunk ...tech 101
Uni
I've been struggling with my second gear and while cleaning my bike i noticed that in second gear and on 1 or 2 at the back (whatever it's called) there's an odd noise - and its only when pedalling, but i notice the chain in connecting / rubbing against the silver bit ...
what must check, adjust, fiddle with  :blush:
uni, not sure what you mean but
you are either cross chaining i.e. big ring front, big cog at the back. This is a big NO-NO
or
your limit screw on your front derailleur (the silver bit) is not lekker and rubs when you are in your granny, (big at the back, small at the front
The barrel adjuster on your shifter needs to be released a little bit... turn it anti clockwise about a half turn and then check again.
Uni is like me, we talk in pics
http://ep1.pinkbike.org/p4pb4800350/p4pb4800350.jpg
hahaaa yeah thanks for that - although in my case pics are because i don't know what the bits are called. I would have been looking around the back derailleur  :blush:
i shall adjust my barrel adjuster tonight and see if that helps - will revert.
oh yeah… sorry pic in OP is when bike was upside down
Problem Solving Check:
Turn the barrel adjuster 50% out or in from shifter position.  Do settings as per attached doc. Can't see whether you are running two or three chainrings. If three, set to middle ring and shift to smallest or largest sprocket, if chain rubs against outer plate turn adjuster in or out to fine tune.
FD - Problem Solving Check.pdf
You guys rock, thanks all. Not perfect yet, but much better. Will tweak it a bit more but at least now I know what to do if it happens again. Merci, Hubland.
