Building a Cyclo Cross bike
Meerkat82
Hi Guys and Gals.
I went cycling with my kids and I can't cycle with them next to the road and I don't want them cycling in the road.
So I had the idea of building a cyclo-cross bike.
Now I understand I need to buy a steel frame and road components older brake calipers en then the nice bigger wheels...
Have any of you ever done this before ?
  • Replies 2.2k
  On 11/26/2014 at 9:46 AM, samson99 said:
i am in the same boat as you. all I need though is the cyclo cross frame and wheels as I have everything else off a old bike.
So I understand a steel frame gives the tyres enough space.
or is there a certain type of frame I should look for?
I just bought a Cotic roadrat frame for this - current plan is to have it painted and the caliper mounts stripped off - going to be disk only.
I might run an old XT 3 x 8 setup on it that I have - need to figure out what to do for brakes/shifters still.
An old steel road bike frame isn't quite the same as a CX specific frame.
Geometry will be different, so just check that out first.
I guess if its just for riding with the kids then it should be ok, but I would be nervous to build a full CX bike using just any old steel road bike frame.
STI's will work - just to find 3x8's...
A steel frame does not automatically equal tyre clearance - there are plenty of steel road bikes with VERY minimal clearance for even 700x23 tyres. My Columbus steel Gemini for example.
Steel is opted for in CX bikes for its comfort.
CX bikes/ frames will also have different geometry to road frames, to accomodate the off road use.
If I was you, I would go with a CX specific frame or monstercross a MTB frame...
  On 11/26/2014 at 10:15 AM, Ryanpmb said:
A steel frame does not automatically equal tyre clearance - there are plenty of steel road bikes with VERY minimal clearance for even 700x23 tyres. My Coumbus steel Gemini for example.
how would one monstercross a MTB frame?
  On 11/26/2014 at 9:28 AM, Meerkat82 said:
Hi Guys and Gals.
I've just got rid of my road bike and built a CX bike so I can maintain my road riding but explore more back roads on the same rides...
I use this bike to take my daughter for rides too...
Drops.
Rigid fork.
Usually slightly smaller than MTB tyres but bigger than road - 1.8 - 2.2.
