How do I work out how much to increase stem length?
brucem76
Hey guys - I'm 195cm tall on an xl frame (should be an xxl frame, but SA doesn't really bring these in) - it's obvious to me my handlebars are too close (hands get numb while riding, can't get my wrists in right position as there's not enough space)
How do I work out how much longer I should make stem, and how long is too long (I assume at some point I start introducing other problems?)
  • Replies 179
beg or borrow a stem from a fellow hubber? What stem you have now and what seatpost?
setback seatpost can help if you don't already have one.
I have a 1.92m 140kg friend riding XL with 100mm stem as he removed a 120mm which was on the bike. so 120mm, 130mm all should be ok... also have you tried wider bars? what bars you got now?
I would advise you to go for a proper bike setup otherwise you will spend money and time trying endless options! Get your seat position correct first before you play around with short stem/wide bars or long stem/narrow bars, etc. I would think an XL frame is plenty big enough at 1.95m.
Firstly - how wide are your bars?
Hi Bruce
If your hands go numb then you might be pushing to hard on your bars. (to much weight forward)
you can try and lift you stem by adding 5 to 10 mm spacers under and see if that works. Cheapest option....
You might be stretched so shorten stem by 10mm second option
My 5cents
Bars do make a lot of sense - I feel like I have to curl my hands in slightly to hold my handlebars... but a jump from 720mm to 760mm sounds very minimal - 2cm on each side?
I am 192cm I ride an XL with 800mm bars ( spank 777 ), 70mm stem and Reverb dropper. I am busy experimenting with a bit shorter bars and I am finding the 20mm shorter is a slight amount more comfortable But ill see where I end before cutting. I hated the longer stem on my bike(120) and went down to a 90mm. I feel a lot more comfortable with the 70 however.
Have you done a proper bike fit/Ergo fit?
Helpful, thanks. So maybe I start by putting some 800mm bars on my 100mm stem (which will definitely be too big/long as a combo), trying that, then cutting back on stem length, and then cutting a bit off the bars if need be?
  On 2/3/2015 at 8:58 AM, El Capitan said:
EISH!!! Way too narrow for you, dude. Get a set of the Rapide 780mm bars, before you do anything to your stem. Someone your height shouldn't be on anything narrower than that.
And they're CHEAP!!!
http://rapide.co.za/product/rapide-rise-r-780-9/
Seriously. Change that, then see how it feels, then change stem later if necessary.
Thanks - very helpful - something felt wrong for sure, cool to have someone confirm that my bars are way out....
It makes a very big difference, trust me. Even going from 760 to 780 is quite a big difference.
I'm 6ft dead (180) and I'm running 780's on a 40mm stem.
Cut back on stem before bars, mate. You're a big boy - you need wide bars.
But first - get the bars, and test. If still wacky, then get a 70 / 80mm stem and try from there. Should work out nicely, and then you're almost in the sweet spot ito bar / stem combo
